SYO237
SyTy Registry
I thought it would be appropriate to have a thread that contains some quick easy links for standard upgrades and fixes for our trucks. Here is a collection of "how-to" articles written for SyTys featured on HowTune:
CHANGING THE HEATER CORE
https://howtune.com/articles/1-changing-the-heater-core-on-a-gmc-syclone
REMOVING THE ABS
https://howtune.com/articles/5-removing-the-abs-on-a-gmc-syclone
INSTALLING LOWERING BLOCKS
https://howtune.com/articles/12-installing-lowering-blocks-on-a-gmc-syclone
USING GM TOP ENGINE CLEANER
https://howtune.com/articles/13-using-the-gm-top-end-cleaner-on-a-gmc-syclone
INSTALLING CUSTOM FACE GAUGES
https://howtune.com/articles/14-installing-custom-gauge-faces-on-a-gmc-syclone
HOTWIRE THE IC PUMP
https://howtune.com/articles/16-hotwiring-the-intercooler-pump-on-a-gmc-syclone
CHANGING PLUGS WIRES CAP/ROTOR
https://howtune.com/articles/21-changing-plugs-wires-cap-and-rotor-on-a-gmc-syclone-typhoon
REPLACING VAC LINES
https://howtune.com/articles/40-replacing-vacuum-hoses-on-a-gmc-syclone
REMOVING THE BED (SYCLONE)
https://howtune.com/articles/45-removing-the-truck-bed-on-a-sonoma-gmc-syclone-or-s10
TURBO PORT MATCHING
https://howtune.com/articles/43-port-matching-the-turbo-on-a-gmc-typhoon
REPLACE METAL IC LINES
https://howtune.com/articles/46-replacing-metal-intercooler-lines-on-a-gmc-syclone-typhoon
REMOVE EGR VALVE
https://howtune.com/articles/47-removing-the-egr-valve-on-a-gmc-syclone-typhoon
VAC LEAK DETECTION
https://howtune.com/articles/55-finding-the-vacuum-leak-on-a-gmc-syclone-typhoon
REPLACE LUMBAR SUPPORT HOSE (TYPHOON)
https://howtune.com/articles/159-replace-the-lumbar-support-hose-on-a-gmc-typhoon
OVERHEAD CONSOLE BULBS CONVERT TO LED
https://howtune.com/articles/242-convert-the-overhead-console-bulbs-to-led-on-a-gmc-typhoon
VALVE SEAL REPLACEMENT
https://howtune.com/articles/325-replace-the-valve-stem-seals-on-a-91-93-gmc-syclone-typhoon
SYTY TROUBLE CODES - CHECK ENGINE
https://howtune.com/articles/362-access-the-trouble-codes-on-a-91-93-gmc-syclone-typhoon
HOW TO ADJUST TV CABLE
https://howtune.com/articles/368-how-to-adjust-the-tv-cable-on-a-gmc-syclone-typhoon
REMOVING THE GRILLE
https://howtune.com/articles/51-remove-the-grille-on-a-gmc-syclone
REPLACE IDLER ARM
https://howtune.com/articles/52-replace-the-idler-arm-on-a-gmc-syclone
INSTALLING POWER SIDE MIRRORS - TY MIRRORS ON A SYCLONE
https://howtune.com/articles/53-installing-power-side-view-mirrors-on-a-gmc-syclone
CHANGING THE THERMOSTAT
https://howtune.com/articles/101-changing-the-thermostat-on-a-gmc-syclone
REMOVE FRONT AXLE NUT
https://howtune.com/articles/112-remove-the-front-axle-nut-on-a-gmc-syclone
CHANGING THE CV AXLE
https://howtune.com/articles/135-changing-the-cv-axle-on-a-gmc-syclone
CONVERT GAUGE BULBS TO LED
https://howtune.com/articles/241-convert-the-gauge-bulbs-to-led-on-a-gmc-syclone
HOLLEY DOMINATOR TCC LOCKUP SETUP
https://howtune.com/articles/258-ho...sting-the-tcc-lockup-control-on-a-gmc-syclone
REMOVING THE ABS
HOTWIRE THE IC PUMP
REPLACING VAC LINES
TURBO PORT MATCHING
REMOVE EGR VALVE
VAC LEAK DETECTION
REMOVING THE GRILLE
REPLACE IDLER ARM
