how to turn fuel pump on?
Typhoon #1133
how do you turn my fuel pump on under the hood? i was told a gray wire on the passenger side. i dont see one on the passenger side. any help here?
thanks,
keith
ALLTRAC
I had to do this about a year ago so i don't remember what exact wire it was but I do remember that it was on the driver side firewall. There should be two relays of which one will be the fuel pump. If you have a test light and a friend you can find out pretty easy what wire it is.
Ryan
smeagol
There are a couple relays on the firewall, it is just to the side of the power distribution block on the firewall. Follow the wires out of the relays, there is one that is not connected to anything, it is grey, and has a small plastic connector on the end. Put 12v to that (do it with a short section of wire from the power distribution block) and the relay will trigger, powering the pump.
