How to Tune Suspension?
QWERTYphoon
Motley Driver Award 2009
Anybody know how to tune a front coil over suspension? I am having a hard time finding the "middle" of the suspension up front. To tight and the truck looks like its popping a wheelie, to loose and it bounces all over the place. If I lower the back and take out the spacers the rear is too low and tight and the front is perfect. I have RPM Arms w/ 1" spacers, rear is rancho 9000 w/ 3/8" set back plates if I lower the rear w/ 1" blocks and the set back plates it bottoms out on the stops and stock leafs, and a belltec sway bar. My best guess is to get the rear to cooperate with the front w/ no spacers up front. Any advice?
Re: How to Tune Suspension?
I just set the ride height for the front coilovers to what I wanted and then adjusted the knob on the Qa1. From what I have expereince, The QA1 like to on the 2 or 3 position (loose) for street driving. If they were set in the middle, they will jar you your filling out over bumps in the road.
I would personally use the spacers on the RPM Coilover because of the low mounting point and short travel of the QA1's.
QWERTYphoon
I have my knobs set at 6. I will try lowering the setting and as of right now I have the spacers in. Thanks
supersports10
set the front where you want it and are happy. if this means taking those "spacers" out, then so be it.
as fo the back.......you obviously want to have the truck lower, because it looks good right??
BUT.... it rides like ass.......solution??? look at the front of the overload leaf, go back 2" from the front, and drill a 3/8 hole in the center of the leaf. get some energy suspension bump stops, and install them in this hole. by doing this you are engauging the overload sooner, under hard compression (big bump) the overload will actually be used.
under all but 1% of daily uses sy/ty's never use the overload, period.
by doing this you are allowing the overload to do it's job sooner.
now dont get me wrong,...under normal circumstances (small road bumps) the truck wont be riding on these, it is just for bigger bumps.
if you like this but want it to engauge even sooner, add one to the rear side of the overload.
you can also tune engaugement with bump stop height. energy suspension sell's different height bump stops.
another side effect is the truck will plant the tires harder on a boost launch.
i have had this done to my syclone for a year now, and absolutetly love it. no more bottoming out (i have 2" blocks, plus the factory wedge.
QWERTYphoon
I just feel the need to share this pic w/ everybody. I think Renz is in to stuff like this? we will find out?
hatrik8
Got pics of this?
supersports10
hatrik8 said:
Got pics of this?
here you go.......
easy as pie..
these are the rubber bumpers that i used, then lopped 1/2 of them off. they are a lakewood traction bar replacement bumper, from summit, or jegs.
use these if you want less.
box and part # for the red ones.....enjoy
Flyin Ryan
hated cuz he drives fords
You should put this in the tech articles section so it doesn't get lost and more people can make use of your good idea :)
Quickstop [UK]
Combating adversyty.
Sorry to resurrect an old thread but I was wondering how to tell what position my QA1s are at and how to adjust them.
I have a very rough ride at the moment so would like to soften it a little.
Thanks!
Mark
ziembic
Most people count from the softest setting to the hard. Each click is one count. I believe QA1's are 12 clicks, so count toward the minus to see where you are. I cruise at 3 or 4 unless I am racing.
Quickstop [UK]
How do I know where 4 clicks are from? How do you zero it? The wheel goes round and round.
Isn't there something about damaging it of you turn it too many times? Thanks!
bezerk
you shoudl be able to close it somehow. it should't go round and round and round
ziembic
My QA1's have a stop at all the way down and all the way up. I am pretty sure it was 2 full turns.
cheatham2492
They do have stops they should not turn forever. thanks for the good info Supersports 10.
Dan Cheatham
Quickstop [UK]
Update - I have 16 clicks. What does + mean and what does - mean on the shock? I have it set at 8 for now.
