ed hess
race or get outta the way
Trying to determine how much fp to use with various ultimate/vortec T3xx settings.
When I was at t220 I had zero knock counts. Using 110 gas
Changed to t318 and saw less than 1 degree kr at shift points using 110
Changed to t320 and saw 4-5 kr at shift points using 110 gas.
Changed gas to 116 octane and saw the same results on the t318 and t320 settings. They were virtually identical.
all runs were at 21psi.
Erue and falco both told me I may be running rich per the dm I sent them. However I don’t have the wb02.
So should I just try lowering fp to see if it makes the kr go away and how much to lower it? Base is currently 45. Lower it, 1 /2 psi, 1 psi? I imagine there isnt any standard here…
I think that the kr is from to much fuel since it increases as you step up in the ultimate settings, which as I understand keep the same timing but just add more fuel at wot with the exception of the jump from t220 to t318.
I am still very new at this kind of tuning so can someone tell me if this sounds like I am understanding this clearly?
ed
ed
