ZMann said:Air/Air cleans up certain parts of the engine bay. No more water leaks, hoses etc!
ty1435_4.3 said:I had one made from the Izuzu truck and have it with my T-72 and there is almost a 95 deg. difference. Awsome
92BlkTy said:working on my setup now. since weve established that ATA is the best for street use, what about Dual ata?
I bought a Saab9000 IC cheap, and im thinking of picking up a stock top mount Subaru WRX one cheap from a friend that went FMIC. i figgure put the 9000 IC in the Grill, and the Subie' in the CCHE location.
would that be worth the effort?
smeagol said:I agree with you Jer, but Dequick setup was executed *decently*, as the cores on that system were run in parallel, rather than series. This setup can work well if designed properly, IMO.
Just something to keep in mind if you are planning DIY stuff.
Anyways, keep an open mind, cheap projects are fun, you never know what you'll learn![]()
I don't know anything about that set-up but you would need to be running your turbo beyond it's efficiency level to require the use of two intercoolers.
