more pics:
I finished biting out the left side wall
upper right smoothed down.
lower right
lower left
upper left
prior to sanding with the harsh carb roll
almost done with the harsh carb roll
I finished cutting down and smoothing the other corners. I tried to make smooth transitions on the upper humped side of the ports.
There were some areas that the casting process left some nasty depressions in, so I've tried to get those down far enough to at-least smooth them out a bit.
The thickness of the walls is something to keep in mind, but there does appear to be a lot of material left, I don't think it will be an issue at all.
next, finish with he harsh rolls, then the finer carb rolls then the flapper and on to the 2 'grits' of cross-buffs.
