How do you remove fender cladding help
JoveDios
1993 Gmc Typhoon #0627
My driver side fender clasding has broken tabs so I wanna remove it and send it to get fixed but I don't know how to go about removing the cladding also might just remove all of them cus thinking of getting her repainted
SYO237
SyTy Registry
Re: How do you remove fender cladding help
Specifically the fender...
There are 2 bolts that hold it onto the lower rocker cladding. You will see 2 access holes in the front of the rocker cladding that you can use an socket and extension to reach up and get to the bolts.
Remove all the bolts from the tabs on the inner side of the cladding going around the fender well.
There is a front tab that wraps around to the front of the fender where another bolt is. The easy way to access this bolt is by remove the grille.
