Re: How do we know what FP to tune at?
It's just a six said:
When I dynoed my Sy, most of the runs, the A/F ratio were in the 13's.
Peak HP & torque was around 13.4 A/F ratio. 386 HP, 550 FT. lbs.
10 -11 A/F ratio is way too rich.
A/F 14's part throttle is OK, maybe go a little richer or try maybe pulling some timeing out? Is this under boost,part throttle, the pinging?
I'll state it again for others 10-11 A/F ratio is way too rich!!!
There is a point of fueling too much will hurt it.
Most engines produce maximum power (with optimized ignition timing) at an air-fuel-ratio between 12 and 13.
Dyno AFR != road AFR. Run a WB02 truck on a dyno, and watch the AFR, then run on the street, and watch the AFR. You'll be at least .6-1.0 richer on the street. Also, I don't trust the calibration of most WBo2s that dyno shops have any futher than I can throw them.
Over the years, I've tuned about 30-40 trucks for pump gas. The leanest I ever got one was about 11.9, and that was my own. And it ate 2 piston ring lands.
I find some trucks that won't run more than 14 psi unless you fuel 'em up. 10:1 is a bit excessive. Typically 11.2-11.5 works, sometimes leaner if I can get by with it.
And, that's on the cheapest 91 I can find. I stopped tuning pump gas trucks on "ringer" 93-94. The quality of pump gas varies dramatically, so you need to tune for the least common denominator.
Race fuel is an entirely different beast. I've run as lean as 12.8:1 intentionally. And it got faster. It also started to knock a couple degrees on the shifts. So, I pulled it back to around 12.5. I don't consider a tune that knocks a good tune. (Even if it is faster)
There is power to be made from a certain degree of leanness... but it comes at a price. I know people running 13.8s to 14s at WOT... but they're ok with the parts failures that come with it.
