Hi my horn is not working. I press it and I hear a clicking sound. Is a replacement horn the fix for this or could it be more complicated? Also can someone help me with the location of the horn so I can try to replace it. Thank you
Sounds like the relay. You can find the horn under the air filter. Hotwire it to see if it still works if it does you must have a break somewhere. Did you also check the fuse ?
Yeah fuse is good. Changed the relay. Didn’t work but still the same clicking sound from it. What do I need to remove to get to the horn? Thank you again
