Re: Hopping off the line
Vaders Sy said:
If some have experienced the hopping off the line, I was wondering what could be done to keep the tires planted. I just got my Nitto drag radials to replace the 4 year old Yoko's AVS ES 100's. The suspension I haven't touched since I have owned it for the last 4 years. I guess I will try the drag radials to see if that helps, if not, looks like this year will be suspension work.
....a couple of things come to mind:
1. Battlebars (Im not knowlegeable on), Caltracs (of which I have, with fiberglass springs),
or ladder bars work to cure wheel hopping/axle wrap during acceleration
2. Shocks are a key component as well (if yours is worn, or if your using the Ty
air suspension factory setup, this probably hinders a bit)
3. Nitto Tire pressure (a setting below 15psi is not recommended), and while
Nittos are a harder compound (and thus last longer) too much burnout actually
overheats the tires and creates as much problems as too little burnout/heating.
(I think temps are suppose to be arount 120 degrees, but dont quote me on this).
4. Pinion angle also can be a factor (if you have lowering excessive). As
can be weak springs.
5. Lastly, if you have fiberglass springs, while they are lighter, it is critical that
you torque them properly (or you can crack/damage them causing breakage).
Also, heat damages them if your exhaust touches or rests on them). There
are differing opinions as to using lowering blocks with fiberglass springs
(ie whether they entice breakage or not). Even placement of the "angled shim"
could make a difference. And of course, every spring has a spring rate
which varies from soft to hard (affecting rebound rate).
You didn't comment on whether you had a rear sway bar or not; or whether
you had stereo equipment or extra weight in the rear (Im assuming not).
Hope this helps a bit...
Let us know how you like the Nittos, as some like them for their
wear rate (and moderate traction on the strip, with better than average street traction)
and others say the 6/32 tread (and not the compound) in rain causes hydroplaning.
While not as bad as slicks or M/Ts, BFG, or Hoosiers, having the rears and fronts
"twirl ya" can be alarming in a downpour. If you were on the Power Tour, there
were many instances of this
-Larry Brown
