SpoolingTurbo6
Installed a Holley EFI dominator on a Syclone.
The engine will start, run, then stop.. Almost like the coil wire is pulled. It will not fire again until the system / key is cycled. Sometimes having to disconnect and reconnect the efi power completely before the fuel pump will cycle on again. (this has happened twice)
The coil has 12v on the pink wire before, during and after cranking.
Red/white wire has 12v before, during and after cranking.
Cloned my working tune over from my Typhoon. Few changes. From Ty to Sy. And updated the firmware, and software to v4.0
1. Injectors ( turbotime 75 #) low impedance. (2.4ohms)
2. RaceTronix hot wire kit.
3. Holley fuel pump relay powers firewall relay, powers RaceTronix
Other than injectors, I shouldn't need to change anything in the setup to run the Syclone motor.
I set them as low impedance, 73psi, 60lb flow rate,
Anyone had a similar issue?
Thanks
Tyson
Thanks
Tyson
