high temp ceramic coating
QUICK STORM
B.A.M.F. BMW Tech
where do i get this done to my exhaust manifolds, would prefer to go to someone local in my state and not looking to ship them out to somone.
wshattuck
1BADGMC
Re: high temp ceramic coating
i went that route the first time... i had a local guy do it, i paid for hitemp 2000 coating but after 100 miles it already was cracking... waller just pulled them off and i sent them to Jet-hot to do it right!! it was around 400.00 for jet-hot 2000 for the headers, turbine housing, and downpipe...
will
ZMann
vertically challenged
I sent mine to Swain.... can't remember exactly how much the exhaust housing and dp was though. Thinking around 100-150
James Thomas
"NO CLASS"
So Will & Zach, good results? No chipping cracking fading? A lot less heat? Give us da scoop!
_____________
James
If you do have them coated, you probably want to have them bolted to set of heads (A good use for the stock heads) so they don't shrink when they are baking in the oven.
ZMann
Shouldn't be an issue if you send them off to be professionally done. I know Leroy has his manifolds, exhaust housing, and downpipe coated, and he noticed a big difference w/ underhood temps. Its pretty obvious when you can touch the coated metal after driving.... you can work on the truck sooner also, instead of having to wait for cool down.
420
Broke Ass Racing
Swain did my turbine housing, and Jet-Hot did my headers. No complaints about either :)
ZMann
army helo pilot said:
does that affect performance though or is it just a cosmetic mod?
Not sure how an exterior coating would change the performance enless it was heat related performance? I suppose with less underhood temps you IC will stay a little cooler...so yes, it "could" affect performance. A lil.
420
Broke Ass Racing
SyTyJedi said:
More heat in the exhaust is more better for turbos.
Actually, more heat in the exhaust is better in general, as it helps increase exhaust velocity. :) I do know several people who had their turbine coated, and with no other changes saw an improvement in turbo spool. I just did mine because it's pretty ;)
H-TOWN-TYPHOON
You're killin' me, Smalls
Does anyone know anything about polydyn? They are local to me and I have read some good things about them.
www.polydyn.com
