sy1907
SYCOTIC
Syty patrons, I got a doozie. In a nut shell, I have been trying to pin down this shake for a few months. Any ideas would be greatly appreciated! A little something like this:
I have a stock syclone except for the exhaust which was replaced by the previous owner. Ever since I had it on jack stands for 3 weeks, it has ran with a horrible shudder. The only thing I replaced was the transfer case when it was up. NE ways, I, with the help of Buster, checked the fuel return lines, replaced the fpr, replaced plugs, wires, cap, and rotor, ohmed the injectors, checked the intake for cracks and bad gasket, and have found nothing. Buster put the wideband 02 on it, finding it running extremely lean (18:1) about. What in the hell is causing this? Even though there is good pressure at the rail (43psi), it is still running lean. I heard it was wrong to use injector cleaner, what does it exactly hurt? Seriously, I really want to get this squared away b4 winter, which is already here, so any help would be appreciated. A big thanks to all and Buster( 11.0 @ 122).
