Help quick!
JUGGERNAUT
There is a hole in the side of the block on the passenger side, about the same level as the motor mount but all the way forward. On our trucks its about 2" deep but there is no passegeway through to anywhere. On the non turbo trucks the passege is drilled through and there are 3 bolt holes to hold something on there. What goes there? Can I make a block off plate for that?
Brassmonkey
Cruzin' Mel Man
Re: Help quick!
I think you are talking about the manual fuel pump boss.
UR50SLO
V6+2=LSXCamaro
Re: Help quick!
That would be for where the fuel pump boss used to be. It's now just a blank opening in the block. It won't be a problem leaving it open.
With all the stuff on the truck you won't see it anyhow.
~Scott
ghettosled
SYTY SUPERSTORE
Re: Help quick!
when you are ready to buy something nice that is actually designed for the 4.3 here ya go :)
http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
JUGGERNAUT
Re: Help quick!
Thanks fellas, I ordered one off ebay. Mike if I saw that first I definately would have got it from you. On a seperate not, do you have the intake gasket set? If I cant get one overnighted tomorrow morning I cant go home for christmas. If not, anyone know where I can get one?
ghettosled
SYTY SUPERSTORE
Re: Help quick!
call us monday.. i should have the "intake set" in stock otherwise i can break a head set and send you what is needed. if you want to do paypal just email sales@raceprovenmotors.com with your info and i'll send you an invoice.
