HELP No Boost.
mildtowild
Custom Upholsterer
My ty has no boost and stumbles a bit. I NEED HELP!! Need to fix so i can get to Radiohead tomorrow!!
SkyeTy
Re: HELP No Boost.
what do you have done, what have you done recently, and is there any other symptoms, at cuise, idle, wot ect. what rpms is it stumbling?
mildtowild
Custom Upholsterer
Re: HELP No Boost.
the truck is basically stock.All i have done is change the fuel pump. I am also getting a lean code Before and after fp swap. havent driven much , stumble off idle for sure dont know about wot.
mildtowild
Custom Upholsterer
Re: HELP No Boost.
i put in racetronix kit so am assuming is good. i ahave a snapon scanner do display live data if it helps.
mildtowild
Custom Upholsterer
Re: HELP No Boost.
Well i am now getting boost but runs rough after?? then clears? afr shows 14.7 at idle 12.8 on boost and showing a lean code?? bad o2?
SkyeTy
Re: HELP No Boost.
what is your long term fuel trim? cross counts?
are you useing a modis or solis or what?
any problems idleing?
Re: HELP No Boost.
Your O2 sensor will F everything up if it goes bad. Datamaster usually lets you know if its toast. AFPR can cause issues. Mine did. Check vacuum lines. Spray carb cleaner around and see if RPMs rise. If they rise after spraying it in a certain area then you have a vacuum leak somewhere. Blow compressed air into wastegate canister. Check to make sure you didnt burn through a plug wire at the down pipe.
mildtowild
Custom Upholsterer
Re: HELP No Boost.
I did find one of the plug wires not snapped down properly. could this be my stumbling problem? now seems to be boosting. if i am showing a lean code and the afr is 14.7 idle and wot is 12.7 is this contradictory? i looked at the plugs and they are slightly black. ant thought?
what are these?
"are you useing a modis or solis or what? "
Re: HELP No Boost.
If your Ty has been driven for any amount of time with the plug wire not snapped down it can effect you STerm and LT Counts for fuel. I would put in new plugs pull the ground cable off the battery to reset the computer. Then just take it for a nice drive and let the ECM relearn its fuel tables.
mildtowild
Custom Upholsterer
Re: HELP No Boost.
fuel trim 128
lt trim 150
the o2 mV starts our at 100+ then drops, when it hits 4mV the engine light comes on.
SkyeTy
Re: HELP No Boost.
those are snap on scan tools, i was just wondering what model you are using. i dont remember how to spel them though.
pinellas50
New Guy
Re: HELP No Boost.
Does it break up/sputter under mild boost at mid rpm or higher? If so, you and I MIGHT be chasing the same problem.
Long story on mine. But I still haven't found it. So I'll be watching to see what you come up with. So far I put in the Walboro, Racetronix harness, AFPR, new distributor, and new cat converte.
But my problem included the addition of L35 heads so our problems might have nothing to do with one another.
Have you pulled the plugs yet?
mildtowild
Custom Upholsterer
Re: HELP No Boost.
mine seems to be 2000rpm and higher. could be the same.
