4C FED
Absolutum Dominium
I pulled the dist. and timed it again, checked my plug wires (2 were not fully seated, Doh!).
I got it started.
But after priming (priming tool) it for a couple of minutes then starting it, I have very little oil coming from the pushrods after about 30 sec's. of the motor running on its own.
So I turned it off.
When I used the priming tool I had oil coming out the turbo supply line and I started to see a little come out from the pushrods, so I figured I was done priming.
SHOULD I BE WORRIED? or is this normal.
I got it started.
So I turned it off.
