Aeroking said:For a W2A setup. I have a hardwired Johnson IC pump, and i'm thinking about getting an ATR auxiliary heat exchanger in front of the rad.
Do i need to add a second pump, or upgrade to a ATR pump, or am i ok with the existing Johnson????
turbodig said:Take a Johnson, two chunks of hose about 3 feet long and a bucket of water.
Put one hose on the suction side of the pump, and put it in the bucket. Put the other chunk on the output, and hold the end up to your chest or so. Turn the pump on.
You'll see just how much the Johnson flows when it has a bit of flow resistance....
Aeroking said:ok.... well, without actually doing it, I'm guessing it doesnt flow too much with resistance??
