HEADS.....
jwaller
Evil Genius/SyTy Guru
L35's with valves are worth about 25-30 over stockers and vortecs another 15-25 depending on lots of things.
smeagol
are heads worth the money?
It depends...
On a stock truck? bang for the buck, do the recipe type stuff... look on Sportmachines, read up on the board... I wouldn't go with heads until I redid the motor with strong parts and had money to really fund a good buildup.
how much hp increase will good set of l-35 heads give me?
It depends...
On what's in the rest of the combination. If you use a cam, a larger turbo, good fueling & management, and go from stock heads to ported L35s... you'll see huge gains. If you are on a stock truck and go to L35s... might not see much gain at all.
Yes, the stock heads don't flow much... but the stock cam is very weak, the stock exhaust manifolds start choking off then too, and the stock turbo has horrible back pressure...
jwaller
the L35's will have the notch in the top of the intake runner. only L35's have this notch. only other way is to know casting numbers. and yes I'll be at the auto fair.
_________________
TE-60, ATR headers, Vortecs, TCS converter, 50# chip, NOS Profogger, Built by J&G Racing
<font size=-1>[ This Message was edited by: jwaller on 2002-03-19 08:47 ]</font>
