Re: Headers Glowing ?
You'll actually get beter idle quality @ around 13:1.
Get the CCOM program, a laptop & hook it up via the cable. Connect via the communications drop down at the top menu.
Then select View from the top menu, Closed Loop Parameters & then AF Ratio Table.
You'll see a bubble hovering around. Try changing the cell/cells that the bubble is touching to 13.0.
See if this improves the glowing header problem.
Check your timing.
Get a timing light. Preferably a "dial-back light" if you don't have a Fluidamper or ATI damper that have numbered marks on it. Hook it up to #1 plug wire and read what the timing is.
Now select View from the top menu, then Spark Functions & then Base Spark Table.
You'll see a hovering bubble again. Make sure the number that the bubble is on matches the number your read from the damper. Don't change anything here, yet!
What is the number that the bubble is on? Do they match?
