Hard lined vacuum lines
Black Knight
I Glow Therefore I am
Has anyone ever done this, or attempted to do it?
I've been contemplating replacing as many of the rubber/silicon vacuum lines as I can out of steel (or braided where applicable) to try and eliminate this as a future issue, plus it'd look cool. :cool:
Anyone, tried and succeeded, failed miserably, day dream about it, ordered parts five years ago and they're still on the shelf?
Slyclone
Well-known member
Re: Hard lined vacuum lines
Seen one done up bfore in the AN textile style hose.
My cousin did it in his 900 hp Evo it is all push lock quick disconnect. Very nice approach for a vac system
Id put pics up but this a truck Forum not Evo.
warmpancakes
parker store has all the stuff for Push lock, cheap and you can get extreme high temp lines check valve and tees are cheap
QuinnSY
We used them all the time with the last company I worked for. SMC and Festo are the 2 big companies that manufactures the fittings and hose. The reason I didn't end up using them was they were meant for pressure and not vacuum. I bet they would work for vacuum also, but I decided to stick with the Silicone Vac line kit.
Aeroking
e.i.
you can buy hard brake line with a matte coating on it, and some tube nuts from summit. :2cents:
Black Knight
I'll check out those places, thanks guys.
Sy 2960 do you have any pics you can post and/or a idea of what fittings you used?
SYO237
SyTy Registry
One of our SoFL members did aluminum hard lines. All hand cut and bent to perfection. Shit is killer.
Throw that in with some custom bent brake lines and you'd have one sweet looking eng. compartment. :tup:
GAShan
Actually he did them all in stainless, then polished them.
BoostedSUV
I've been thinking about doing the push lock plastic lines but connecting them to map sensor/fp reg ext would be a problem. Coming off the intake would be easy and clean.
TYTILIDIE
METH HEAD
Its not bad actually, I have my Ty set up that way along with my wifes old Ty. You have to take a Dremel and shave the nipple down and make it a slip fit. Then with CC you literally just push the hard line on and it stays.
MikeRenz
not stock
I've wanted to make kits for this, but I don't have access to a stock truck to use as a template. Maybe at the next wrenchfest we'll do someones truck up.
atomicmecha
I hate rust
I've been planning and wanting to do an all braided line replacement for the vac lines since I got the truck. The entire system was rotting away when I got it and I've done patch work but even those lines are starting to fail. I wanna buy several feet worth of silicon hose with braiding and goto town. Would also love to convert everything to AN fittings and piping.
I'd volunteer my typhoon to anyone that wants to develop a kit. :tup:
GAShan
Darriel's Typhoon. He's going to get pics of one on an engine out of his truck. He says he'll make them if people want, but they'll be expensive (stainless) and he's slow at it.
