Gauges
blkty
Does anyone know what controls the factory gauges i tried to start my truck for the first time since my build and nothing is working it started but we shut it down since we couldnt check oil pressure dont know what it could be no blown fuses
thanks blkty
NecroWolf
lost marbles member
Re: Gauges
i know the temp guage has it's own sensor. the oil pressure guage is off the sensor behind the block. if none of them work on the cluster i would think you're missing a ground wire or something.
WyoSyclone
Re: Gauges
I think either the ground at the driver's side front intake, or driver's side rear cylinder head is the ground for the gauges....IIRC.... maybe check those out.
blkty
Re: Gauges
i checked the grounds looks like there all on but still no gauges any other suggestions
13Pelle
Re: Gauges
Im curious on this problem's solution too....a few o my gauges are now not working.
blkty
Re: Gauges
does the computer control the gauges could the computer be screwed up took out gauges dont see anything out off the ordinary im lost dont know what else to look at
