I almost have it off, i wonder if i'm missing anything? I have the two bolts off, and every other screw i can think of, and something is still holding on to it pretty good. I don't want to break it so any help is appreciated.
The gauge cluster is plugged into the cable behind it. Also, the studs it sits on at the top hold pretty well. Sometimes you have to gently rock the gauge cluster from side to side to get it to release.
4 things hold it in. Two 10mm nuts at the top. Two phillip screws at the bottom on each side. You must wiggle it a little to get it off. Most likely what is happening is that the threads on the studs are digging into the plastic on the inner diameter of the holes and it is making it feel stuck.
