BoostedSUV
Not sure why I'm really asking this as I have my suspicions. I'm getting gas in the oil. The truck sits more than it's driven and pretty much every last part is new. Truck was completely rebuilt from the chassis up. I started noticing smoke at start up (smells like fuel) and I noticed my oil level got high and smells like gas.
I know for a fact when my truck gets hot it's hard to start. When data logging engine rpm reads 7000 (still cranking) and injectors go 100% firing fuel but it doesn't want to sart. I suspect (hope) this is my issue. However it may be possible I have an injector leaking down and the gas is working it's way into the pan. I noticed this a few months ago (high oil level) so I drained the oil and put fresh in it. Haven't driven the truck very much at all since then. Mostly just starting it to move it in and out of the garage. Today I went for a spin and as soon as I laid into it there was a smoke screen out the exhaust. Turned around, put it in the garage and checked the oil. The oil was half a quart high, a light brownish and smelled like gas.
Any other ideas? I'm going to pull the plugs and see of any are soaked with gas. Injectors have maybe 500 miles on them... Fuel pressure is good. I have an electric gauge so I can't see if pressure is leaking down. Just thinking out loud here.
