Syclone0565
CustomMulticades.com
Hello, I bought a 93 Typhoon and it already had the racetronx fuel pump hot wire kit installed. The main hot wire in the system runs up to the alternator. The harness has a male and female connector back up under behind the tank that plugs into the factory fuel pump harness making it a plug and play. I see the relay back there on the racetronx harness that has the Grey wire for the fuel pump and if I apply 12v to it the pump in the truck turn on. The previous owner installed lots of other stuff under the hood electrically. I do not see the two relays by the brake booster so I can not find where the grey wire is under the hood. It goes up and over the tank at the back so I can not find it anywhere. I checked the two factory looms along the drivers side frame rail and there is no Grey wire. Does it go through the Typhoon under the carpet from the rear or somewhere else? If nothing else I will have to run a new wire from the harness back there up to the Holley EFI Green fuel pump wire. Any help, or guesses, would be appreciated.
-Will
-Will
