My Fuel system consists of a 255 Walbro (I remove the stock pulsator), Stock Injectors, AFPR, and new fuel Filter.
I used to have this problem (a few months ago), when I turned up my FP over 47psi my truck would stumble, I also notice that when I used my miti vac to check my fuel pressure that at higher pressures, my Fuel pressure guage would fluctuate quite a bit, but at low FP it was rock solid (for intance 40psi would barely more and 65 psi would +/- 1 or 2 psi)
Anyways I ran a few gallons of Xlyene over a few fill ups (5 gallons total). Now my car stumble like crazy no matter what FP I am running. I look at it the other day and it at idle my FP pressure would pulse down as much as 5 psi very frequently and everyonce in a while stay sort of steady +/1 1 psi for a few seconds and then flutuate. I put a new few filter in today and it has no solved the problem. Could it be my injectors, I can feel the pulsing in my FP gauge and I don't remember that before. I listen to all my injector with an engine stethiscope and hear nothing of the unordinary in any one injector.
