My Ty has been hard to start for the last week. It seems to not be getting FP everytime I turn the key on. Two days ago the fuse blew while I was passing a truck. I replaced the fuse and also replaced the relay that sends FP when you first turn the key on. Everything seemed normal for one day. Now it's not getting pressure again for start up. Sometimes it works, sometimes it doesn't. When its running I am at 42-45lbs cruising and up to 65lbs under boost and all seems fine. It just doesn't always start or have FP build up when you turn the key on and the pump should prime. I have a Walbro pump and a racetronix plug and play unit. They were installed about 4 months ago. One note. When I replaced my pump I missed the part (and threads) about leaving off the pulsator valve until after I had finished the job. Could that be going bad? If it was the pulsator wouldn't my FP at driving speeds be bleeding off? Please help. Thanks,
Eric
Eric
