Syclone0565
CustomMulticades.com
I was told I have 50# injectors. Is there a way of knowing if the injectors are 50#ers? They are a pea green color and I will check in the morning for any numbers stamped on them. Can you tell if they are High or Low impedence by a mark or anything? Thanks. I am trying to figure out why the truck is running bad. I had the injectors sent out and sonic cleaned. I just want to make sure I have the correct ones and they are 50#ers and High impedence.
Thank You
Thank You
