4C FED
Absolutum Dominium
This was on the Ty when I bought it.
I am swapping it out for an A/A unit to clean up the engine bay.
No leaks. Has the mounting tab on the bottom for the center IC support bracket. Although, I've never had the IC blow off of the TB with the aluminum IC hard pipe, silicone connectors & the single mounting bolt up front.
I have added 1/4 ceramic kiln insulation & covered that with Thermotec reflective insulation.
It could use some more of the reflective tape added to help keep the loose corners down.
You can also remove all of the insulation and paint it if you'd like. If you do, please wear a mask as you do not want to breathe the ceramic insulation.
I have also changed out the 3/8" npt fittings to 1/2". The 45 deg. adapters allow the 3/4" hose to make a nice smooth curve around everything to the drivers side.
$450 +shipping, +PayPal fees if you would like to use that payment method.
I also have a oversized IC pump made by Meziere. It has 3/4" inlet & outlet fittings. It works fine, I just no longer need it.
I'll post pics of this later today.
SOLD $100 +shipping, +PayPal fees SOLD
NO PM's PLEASE! I will not repsond.
Any & all questions or offers only answered in this thread.
Now for the pics:
Now for the pics:
