Front swaybar
Transdamn
I just finished the RPM Coilover installation. The previous owner had a different setup on the front for a sway bar I can no longer use.
My question is....... Do I need to run the swaybar? Can I get away without it for a couple of months? What will it hurt?
Quickstop [UK]
Combating adversyty.
Re: Front swaybar
Yes you can run it. Won't hurt anything but your ride will be very different. I would imagine it will be like driving a bathtub.
The sway bar stops sway, ergo if you have none, it will sway and roll.
DaveP
Re: Front swaybar
You will increase understeer by removing the bar. Beware the first few times you go smoking into your favorite on-ramp with some pace on that the truck will behave differently when driven at higher suspension loadings.
Daithi2
Tall Bearded One
Re: Front swaybar
i prefer to have one, the last car i had i removed it to get better weight transfer when drag racing to that effect it was great. as for high speed turns and general driving it sucked. i eventually put it back in.
