front prop shaft upgrade
smebyspeed
the old noob
i did a search but couldnt find anything newer
i need to upgrade my front shaft cause i keep breaking stuff, wheres the best place to get a good upgrade?
93 ty with a 20g and a small shot, 550TQ?
thanks
Six-is-Enough
Use to do a little Boost
Re: front prop shaft upgrade
D&R Driveline inc
768 Chicago Dr, Jenison MI 49428
616-667-1308
I think you'll be happy.
Btw How long have you sprayed that truck???
D&R Driveline inc
616-667-1308
Is the one to get IMO, I have owned a gilbert, stock, and now a D&R.
Last time I bought some 80e shafts there were ~$250 shipped to my door. Gilbert is ~$400 or so now and no stronger at all.
DR uses stock flange on the front, so less work also, just bolts in.
R&C_RallySyTy
Little Big Man
Is the front shaft the normal one to break? I guess this is something I'll fix once its broken...heh. Good info to know.
I would replace it before it breaks.
When they break, I have seen them take out the wiring to rear of truck, fuel pump, and rip sections of metal off the side of the transmission.
Had to jab my size 13 shoe on the floor board of a ty once to push the floor back down also.
I wouldn't WAIT.
R&C_RallySyTy
Little Big Man
I wouldn't WAIT.
even if you have a drive shaft loop to catch it? would like to know more about this...thanks for the good info! :tup:
front driveshaft loop will prevent a lot of damage yes. 99% of trucks don't have one.
Depends also what end breaks as to what gets damaged.
R&C_RallySyTy
Little Big Man
I thought so, just wanted to confirm. Again, thanks for the info. In that case I'll fix it when it breaks.
smebyspeed
the old noob
Do you have someway of watching Knock retard when you spray?
you calling me a retard? :rotf:
i got everything but have the timing turned back, seems ok but thats the main reason i havnt sprayed it much as of late. i also have the full MSD setup. i have another project i should finish next week then i can focus on the ty
side note the 20g is still laying in the floor, avnt pt it in yet just wanted it in the power equasion :tup:
smebyspeed
the old noob
oh yea i got lucky on the 3 times i broke U joints on mine as they didnt blow apart and tear anything up
lucky lucky me , buiding a loop asap :lol:
Six-is-Enough
A little defensive eh?:lol: Nope just wondering. Not alot of peeps spraying their SyTy's. Everone is scared of those fragile(thats french) pistons. Including me.:tup:
Good luck. Are you coming to SyTy nats 11?
Six-is-Enough
Yes. I have never heard of someone breaking a rear driveshaft in a SyTy. The front one gets put into a severe bind when properly boost launched. It is even worse with a busted motor mount. Which is common.
You can prolong a stock prop shafts life by limiting travel in the front end and installing a solid motor mount on the drivers side.:2cents:
Quickstop [UK]
Combating adversyty.
so they are better than stock? that was what i was worried about.
Never heard of D&D before - as long as my gilbert is better than stock as I too paid $400 for one!
Six-is-Enough
Yes both the gilbert and D&D are far superior than a stock prop shaft. D&D is what Blake has been selling for the last 2-3 years.:tup:
smebyspeed
the old noob
i was just playing ;)
i dout that ill make it to 11 to be honest
