Front Posi?
Fastruck91
I have a 1991 short bed, standerd cab, 4x4 s-10 that i am going to turn into a syclone clone? I was wondering if the syclones have posi in the front? and if a posi unit would work do to the AWD transfer case. I have seen 4 wheel burnouts from syclones, is this cause of the amount of power or the help of a posi unit?
Thanks Matt
Re: Front Posi?
No front posi, just plain ole open, pretty much the same axle thats in your 4x4, just without the axle disengagment parts. Most trucks will tend to spin the drivers side first becasue of the left fronts tendency to lift on acceleration, but its possible to spin both fronts smetimes.
They do sell a front locker for the 7.5 IFS and on most trrucks it has been said that you will never now its there, and that it will help with traction quit abit, but once you get to the point of really spinning the front tires on launch, the locker can fight you, becasue its designed to send power to the tire with the most grip, and as each front tire spins it just keeps transfering power back and forth to each front wheel and can jerk the wheel out of your hand and make it a handfull on a hard launch. But on a mostly stock all the way to id say low 11's i wont hurt to add one.
big gear head
axle builder
Re: Front Posi?
I think Power Trax has discontinued the Lock Right for the 7.2 IFS. There are probably still some out there. That was the only thing available for this differential.
