Re: front hubs replacing
Here's a method that has worked for me to remove a well stuck axle / front hub. Its a little off topic, but figured I'd mention it.
1.) Soak the spline / hub interface with liquid wrench or equivalent (after removing the big honkin nut). Preferably overnight or several days in advance.
2.) Apply your biggest manliest 3 jaw puller to the hub & axle, making sure that the arms have a good bite on the hub and the puller screw is in the dimple in the end of the axle.
3.) Crank down on the puller screw to put tension on the hub. Go as tight as you dare / can.
4.) Pull out your biggest hammer (I like a 2lb engineer's hammer) and whack the head of the puller (maybe several times). Usually the puller will get a little loose.
5.) Go back to step 3 & repeat until it come off or you realize you're not getting anywhere. If this doesn't work, it isn't likely to come apart. Your best bet is to replace the axle as well.
And it has been my experience that the last 1/2" or so is an extremely tight fit (like pull it on with the nut). And it should be! Any backlash here will proceed to eat / destroy either the axle or the hub or both. So, tight is good.
'JustDreamin'
