Front Driveshaft explosion...
Rawpwr7
:eek: Driving at 80 mph...it was quick....First a bad viberation and then kabluie. :x
The worst part was when i was slowing down the shaft got to the shifter cable and ripped it off and also noticed ball bearings passing me up.
I just ordered my gilbert shaft :rock: and going to get that in ASAP.
I was reading another post about a cheaper shift cable and wanted to know if they are still available or if anyone had one I could buy off of.
typhoon92
Where did you order the gilbert shaft from?How much was it? I'm thinking of getting two of them.I need to get them before they break on my syclone and typhoon.
I am thinking you could order the Gilbert shaft from Gilbert. Just a thought.
SY2932
Administrator
"11.9# MEGA propshaft. Contact Bruce Gilbert @ Gilbert Driveline in NH 603-623-3061. $318.60 shipped in 10/01."
DanenGraham
Big in the rear
Yeah, i ordered a stock one from dynotech when mine fell apart. $490, and 11.9#'s if your only picking up the end with the U-joint.
skata
why did gilbert switch yoke setup?
in that pic, the shaft bolts to the diff like stock, but now you have to change the diff yoke.
skata
:doh: i was looking at it backwards. :oops:
its been a while since i was under the truck.(that is a good thing :wink: ).
Did the searching for everybody just to be sure the search button still works on the not so relieable forum.
Gilbert Driveline 340 Massabesic
Manchester, NH 03103
Tel #603-623-3061
Fax #603-641-8460
TurboManiacal
Am I missing something here? Just got mine and I don't see where it would attach to the front side of the truck? Where does it bolt up?
Anybody got a working picture?
Ian Turgeon
Cascading Inspiration
The front on that thing is nice. I removed the front of the shaft last night to get to the tc cover, and I was able to remove it w/o having to turn the shaft at all... a big time saver
SY2932
Administrator
AFTER you mark the pinion nut orientation on the front differential, remove the stock flange with a 32MM socket. If you're lucky, you can break it loose with a breaker bar. I had to bust out the impact to remove mine :-? .
Tydriver
TurboLS6 Powa'
I had $317/shipped into my first Gilbert Prop shaft..
then somehow that got traded for a transmission I still havent used before it was installed..
Then I paid like $320/shipped for the 2nd one.
I'm probably the ONLY SyTy'er to order 2 Gilbert propshafts for ONE truck, but it isnt because one failed !! Buy the gilbert, keep the U joints greased and never look back.
