TurboDonnie
My Typhoon has a loose driver side stub axle. There is play up and down and front to back when you take hold of the round flange where the half shaft bolts to. It appears that the axle bearing is shot. The steel c-clip seems to still be there as there is the typical slight movement in and out, you can feel the axle bottoming out on the clip. This loose axle is most likely where my vibration is coming from.
After extensive searching, I could not find the answer to my question which is: Can the driver side front axle bearing be replaced with the front differential still in the truck? I plan to install new seals on both sides as well as the spring steel c-clips while I am at it (they both are leaky). Both half shafts appear to be fine, no boot tears or leaks.
Also, does anyone know the part number for the axle bearing?
Thanks Alot!!!
Thanks Alot!!!
