Re: front diff seal
The seal is the same on both sides. Remove the axle, pull the old seal out, clean the hole, use a little sealant around the hole and install the new seal. Use some oil on the lip of the seal before putting the axle back in.
Be sure to check the axle for wear when you remove it. It is possible that the axle bearing might have gone bad, causing the seal to leak.
