Front Crossover Brake Line
Syty84
Does anyone know the part number to the front brake line that runs along the frame underneath the radiator area. I stripped one of the fitting threads and need to replace the entire line.
gstacky
Re: Front Crossover Brake Line
As far as I know there isn't a replaceable line. You're going to have to make one yourself.
Sportmachines
We have replacement line. In stailess. Whole set for a sy or ty is $195. If you only want that section, I will have to figure out the cost for just that piece.
wheels
I did this on my beater Blazer a couple weeks ago. I got a 60" (I think) piece of brake line with fittings and just used the old one as a template to make the new one. It was a bit long as you can tell by the pictures but it works. I left one end unbent until I fished it where it had to be then finished the bend to meet the fitting at the rubber hose. It might be a little more difficult on a SyTy with the lower I/C.
Syty84
Where did you buy that line from, in store or online?
Damian
Looks like I have to replace the same line too. Found a couple drops of brake fluid in the middle front of the Ty.
