jjorgensen52
NHSTE - I'm the only one!
When I fired up the new motor in the GT, runs beautifully and real smooth, but idles waay high (2K) and then starts to rev higher on its own (I shut it down when the RPM's passed 3000). The IAC, MAP, etc on this motor are the same ones that came off the old motor which idled just under 1k.
I did change the dist. plugs, and wires. The timing, although I have not pulled the timing connector yet, was set at roughly 4* of retard and I haven't advanced it yet (IIRC the spec is 8* advance or thereabouts?)
Things I can think of:
-EGR valve is off and not blocked, possible source of air (although I ran it once before like that, don't remember it revving but could be wrong)
-Possibly a vacuum leak on the intake
-IAC is screwed up now because of the engine being out for ~3 months
Thinking through it right now I'm putting money on the EGR, but you never know. If I just pull the EGR off and toss it, am I going to get an error code?
