cloneman315
is it possible for the truck to be faster with the clutch bad or fully locked up?I thought maybe it would work like a spool etc with it locked up.Mine is bad I had to change the case and the truck go slower lol
I disagre . Yes without a front prop shaft and some slicks in the back I think you could run a better ET. However with a locked up viscous (spool) It be very hard to heat the tires before a pass thus making your 60ft slower. As some of you know a good 60 ft makes a big differance at the big end of the track.
4 of them the same morning they were put in? Sounds like something else may have added to the problem.
