Engine removal
garryf53
do you have to pull trans out to remove engine out of my typhoon? I have exhaust ,turbo, radiator, battery, starter, distributor intake already removed. thanks for any help you can provide me. TYPHOON # 1720 I am going to stay with the 6 cyl.
wildphil
I Love My Ty's
Re: Engine removal
You do not have to remove the transmission to get the engine out. put a jack under the trans. and remove the torque converter bolts.
Norm
Re: Engine removal
See if you can get a service manual, sure helps a bunch when working on these things. And as above posts said, no. But if you have the engine out, might want to pull the trans to change out the pump seal and clean up the trans and transfer case.
garryf53
Re: Engine removal
Thanks for the info I have a chiltons manual and it said to remove both driveshafts dif and trans but I couldn't understand why. engine will be out tomorrow
Re: Engine removal
If you want you can remove the engine mounts and lower the motor to get to the bell housing bolts. (Leave the frame pads.) Makes it easier but not sure if you actually save any time. Just a couple less busted knuckles and fewer swear words.
