Dan_Austin
I found a few threads with tips to make getting to motor mounts easier, and those tips were a big help. I started disconnecting wiring and hoses this afternoon and only have a bit more to go before I can lift the current engine out, and if no family issues pop-up I suspect that will happen tomorrow.
For the folks that have installed an engine in one(or more) of these trucks, do you prefer to fully dress the engine before dropping it in? I was leaning towards having the lower intake, injectors, rail and all sensors installed, including MAP, exhaust and turbo, less downpipe. Thinking that would make connecting water and oil feeds to the turbo easier, as well as some of the very buried wiring. After the engine was in, I planned to prime the oil pump and stab the distributor, install the upper intake and the final bits related to those items.
I'm sure I could figure out any issues that might come up, but knowing what has worked for the community would be huge help.
