92Typhoon1679
I pulled out my motor last month just to Fix all the oil leaks and change out the timing chain and rocker arms nothing internal
When i First Start it its Idles good for about 2 min then all hell brakes loose
its starts missing and has a Very Bad Idle from 600 rpm to 1000 rpm like its hunting.
I turn off my truck and restart is it gets better but not much.
it Really runs Terrible
(((((Update))))))
Ive blown my ECMB Fuse Twice Ive upgraded to a 15 Amp Fuse but it Gets HOT
is it My Fuel Pump?
My Fuel Pressure is set at 42Lbs but when it Starts Running bad it drops to about 20 Lbs up and Down to 42Lbs When i Turn off the Engine it holds pressure for about 1 Hour then goes down to Zero.
its not the Rocker Arms..
Or Timing Chain.
Checked those MANY TIMES.
Its Got a New Distributor New Taylor Wires New Plugs
Ive Tryed EVERYTHING
So i hooked up my laptop and did I Drove it to work.
My BLM is Really High like 170 and Really Low almost 0 at Idle
My BPW is always Low in the red about 1.99
My IAT is 100
Everything else is with in standards
Ive Removed the EGR and i have a Kenne Bell Air to Air
Ive Checked and Re-Checked Timming
Ive Replaced all the Vacume lines Twice.
PLEASE HELP
Ive tryed everything Being in Japan there is no shop to take it..
Im trying to get it ready to ship it back to the states so it has to run good.
This is my Favorite car !!!
I did check my IAC it looks terrible im getting a new one
Update 17 Aug Replaced Throttle Position Sensor
17 Aug Readjusted Rockers Again for the 3rd time with engine running
STILL RUNS TERRIBLE!!!!!!
(((((Update))))))
is it My Fuel Pump?
Or Timing Chain.
My IAT is 100
PLEASE HELP
