MIXEDBREED
Well My 9 second gto is now sold and awaiting bank to clear check. I will now be starting on my syclone build.
I will be using a stock block with some work done to it- bored, 4 bolt mains ect.
Does anyone know of stroker cranks for our trucks that dont cost $3500 fing dollars.
I will be buying some parts from RPM but if that the only price for stroker cranks then i will be using a stock/treated crank. I mean damn my lunati crank in my gto was only a little over 1k.
I will be going with ported vortec heads and a custom cam from rpm.
Eagle 5.7 rods and Extreme duty JE pistons.
Turbo will prob be a 67mm. I will be running twin walbros in tank for the fuel.
If anyone has any info or help they want to add it would be great.
The truck has a built trans with 3000 converter, 5 pinion plants, billet servo ect., RPM coil overs all around, and I have a set of caltraks. I also have a built 4l80e if the 700r4 breaks.
Goal is to run down in the 10s and still be able to drive it.
