Hi, I have a syclone with the battery located in the bed of the truck, 2 days ago, a metal piece had rub both battery poles at the same time, the truck almost stalled and the gauges went wild, from zero to max back and forth, I,ve stopped the truck, got rid of the metal debris, the truck started again but when I floor it, at about 3000 rpm, the truck is bogging and as it bogged, the tack needle does the same, if I lift, everything OK. Can this overload damaged the computer or anything else, the truck isn't running good from this day, help would be greatly appreciated, Thanks...Eric Belisle, Syclone #2662.
