recipe:
1. 30a relay and wiring harness
2. 185deg screw in temp switch (ground)
3. your choice of fans
4. something to hold the radiator in place so you can ditch the uber stoopid factory shroud.
get your parts all together.
mount your fans wherever you want to. also, ignore the mess i made removing the tranny cooler. lol
mount your temp switch in the passengerside head. yes you have to remove that plug. (you can also mount it in the intake if you have removed your water lines for an oil only center section on an aftermarket turbo)
mount up your relay, and wire the temp switch into it.
throw the stock radiator shroud in the trash and sport something that will actually allow you to work on the truck. get rid of that thing faster than a girl with the crabs. lol
now go get yourself 2 scoups of mint chocolate chip, and be sure to ask for sprinkles.
PS: i sell all the parts to do this project.
