EGR removal
AWD
what is your guys opinion on the removal of it? is it really beneficial or noticable on a stock ty or modded one?
just curious to see who has done it and what they think
thanks
Flyin Ryan
hated cuz he drives fords
Re: EGR removal
I noticed with my sy the EGR system would add an extra 30 to 40 degrees of heat to my intake temps instantly when it would kick in.. I said F that and deleted that crap
UR50SLO
V6+2=LSXCamaro
Re: EGR removal
Putting hot exhaust gas into the cool incoming air is about the stupidist (if that's a word) think the factory's done. Lots of build up of black sooty carbon in the plenum.
I blocked the lower part of my intake with a plug. It can't even get into the plenum. The EGR valve is removed as well.
Get rid of it!
~Scott~
Luke
Fish sticks SUCK !!!
Re: EGR removal
lose it, mines bone stock and after turning it off with the waller chip, automatic40degree drop in IAT's
Flyin Ryan
Re: EGR removal
ShuggsRR said:
What do you need to do to get rid of it? Chip?
Yea need to have it disabled in the chip or have a chip that has it disabled in the bin file.. if not you'll get a check engine light when ever it tries to kick in (highway speeds mostly).. also you need a block off plate to replace the open port where the valve was on the upper intake.
ShuggsRR
Re: EGR removal
So I need to buy one? Or can I do it with datamaster?
Flyin Ryan
Re: EGR removal
You can't edit any chip's parameters with Datamaster just view and data log so no you won't be able to do it with Datamaster. If you want to see the difference in intake temps first hand from deleting the egr by viewing it in datamaster.. you can disable the egr by removing and pluggin the vac line to the egr valve on the upper intake. Drive it around and see how much lower your intake temps stay then decide if you want to spend the $10 for the egr block off and $35 bucks for someone to who can program bins to disable the egr on your chip.
Some people take it a step further to make sure no heat at all hits the upper intake by pluggin the port within the lower intake manifold.. i didn't do that yet because I haven't had to take my intake off yet but may end up doing it later one even though im happy wiht the results of just removing that egr crap
ShuggsRR
Re: EGR removal
Thanks for the info...
Im cleaning my intake this week, so its off the truck. I guess this would be a good time huh?
Where do i find a good chip and how much are they?
Re: EGR removal
Disable it in your chip, for instance the Ultimate disable it in most programs. Unless your block off the EGR passage in the head (ie pulling the lower intake), a block plate or EGR valve will have the same effect. The block plate just creates more room in that area.
QWERTYphoon
Motley Driver Award 2009
Re: EGR removal
If you remove your EGR you will see more fuel consumption and worse gas mileage (like 1-3mpg) but more HP due to lower intake temps. The Ultimate Chip (which requires a 3 BAR MAP sensor) has settings (T1-16 through T3-23) that turn off the EGR. Brilliant!
