ebay rotors
i8av8
has anyone ever tried the cross-drilled slotted rotors that are in the typhoon section on ebay? can't afford the corvette swap and even if i could i wouldn't know how or where to begin. my ty stops really well but the brakes squeak too much and the pads are worn. figure i'd give those a try unless someone really objects to them. going for semi-good looks, compared to stock anyways. any thoughts?
jpalmer
Re: ebay rotors
any squeek is from vibration, vibration is because the pads are prob not glued well enough to the calipers, i use either hi temp scilicone or on my less pretty cars, antiseeze. that will stop any squeel, but i have bought the cross-drilled from summit, and they worked fine.
syclone3
Re: ebay rotors
I have a set. They came with pads. For the money. Seem to work pretty well. Came from a warehouse in CA. Got them the next day. Also used some from the same co from ebay on another car and they work well on it.
jasonpickett
Re: ebay rotors
They are ok. A lot of times what they do is buy cheap rotors and cross drill/slot them themselves. It does take away from the strength. You do have to watch out around the holes that are drilled because they do like to crack on the cheaper rotors.
________
Extreme q 3 vaporizer
i8av8
Re: ebay rotors
"watch out around the holes that are drilled because they do like to crack on the cheaper rotors."
yeah, they sure do. bought some PRO STOP (cross drilled) rotors from summit and with in the first year they got heat cracks all around them. thanx for the replies.
