drunk fat girl=broken center console
atkonkler
Is this your bush?
is the center console base able to be replaced where it screws into the floor? A fat drunk lady was sitting in my back seat and did not use the grab handle to get out and pressed her fat knee into the console and it now moves freely when you rock it and you can see the bolts where they went through the plastic still screws in plastic are there! =-O FML
neildemo
Administrator
Re: drunk fat girl=broken center console
Get a SY haul her in the back. But your limited to 500 lbs problem solved.:tup:
Captain Morgan
Moderated User
Bigger washers on the bolts or go to a store and look for a product called Q-Bond, it works great on plastics.
MRKING
New Parts for Old Trucks
Soldering iron melts that shit together pretty good .
atkonkler
Is this your bush?
Ok i knew i was going to be given some heat for the fat chick in the back but hey fat chicks need loving too but it aint coming from me cause Ive driven a moped before which is similar to a fat chick! its all fun and games till your frienda see you and my old lady is is a somali woman and she knows i dont like fat blond chicks with booty do! In case you dont know what booty do is, its where the stomach sticks out further than the booty do!;-) so in the mean time just use jb weld or q bond? Where can i obtain this q-bond?
Ty92Resto
Pictures or it didn't happen :) Actually sorry to hear it but kinda laughing a little
Throws
MRKING
fail :tdown: :roll:
I fixed the front cover that i bought off of Jimmy like that .You cant even tell . While I know it is not made from abs plastic , using the same repair technique is not unheard of . Low temp heat welding together the base polymers will always be superior to multipurpose adhesives . Chemical plastic welding with acetone also is an option . :tup:
Those kids getting under your skin ? You seem to be bringing that unhappy work attitude home with you .:lol:
Captain Morgan
Moderated User
ummm, no, telling someone to use a soldering iron to melt plastic back together is crappy advice. Yes, it does something, temporarily, but unless you add filler rod, just like metal welding, its going to be a weak, brittle repair.
MRKING
I know you dont care , but I accept your apology . :bdayhat:
