SYCLONE#1531
'MOFOFAST
Is it possible to drop the transmission with transfer case attached? I will be doing this on a lift with a transmission removal jack.. installing a new convertor and transgo valve body kit...
Is it possible to drop the transmission with transfer case attached? I will be doing this on a lift with a transmission removal jack.. installing a new convertor and transgo valve body kit...![]()
So how do you do it? Tilt the trans so much you risk that the converter will fall out of it, or that the whole assembly will slide forward off the jack? Doesn't sound real stable or safe. But hey, gravity helps to get shit out.
I thought you have a 4L80? And you advocate cutting shit to do it. Oh well. About what to expect from a guy that can't find a blown fuse.
DaveP...really.
"So certain are you. Always with you it cannot be done. Hear you nothing that I say?"
- Yoda
...and then I put it back under the truck. Just like I took it out only in reverse order, neat huh?
JWALLER, Ive heard the transgo kit would possibly add some longevity to the transmission? The only issues it has at the moment is a very hard 1st 2nd shift when cold. Is there anything I can do for tranny to help it live alittle longer? .500 Boost valve etc??
