driver side window
93typhoon
Typhoon1
having problem with my driver side window. it only goes up an inch everytime i push the button. I have to wait at least 15 minutes and then push the button up and it only goes an inch again. do i need a new motor? where in Vegas can i get it fixed w/o going to a stealership. I also have coolant smell, but cannot figure out where it is coming from. I replaced the heater core a few years back when my passenger side started getting wet from coolant. This time, no coolant leak from the passenger side. :(
SY2455
70's Veteran
Re: driver side window
Welcome to the site.Its time to replace your window motor. If you have the tools,it will take about 2 hours to do. If you do a search someone had a step by step with pictures if I recall correctly.
