Double roller timing chain cover recommendation
QuinnSY
I purchased a double roller timing cover a while ago and while working on it with Dave P. a couple days ago we realized it wont work properly since it seems like it was designed to accommodate for a 2 piece oil pan seal. I have the oil pan seal from Victor Reinz and the part of it that goes in the groove of the timing cover wont fit well like the factory one does. So I am curious what you guys have ran for a timing cover and found to work well. Thanks.
And FYI here is the cover I currently have that doesn't seem to work right
http://www.summitracing.com/parts/SUM-G6300W/
dutchty
Re: Double roller timing chain cover recommendation
I installed the edelbrock Timing cover aluminium #edl-4242 EDELBROCK
with a SBC TIMING POINTR 6 1/4 DAMPER # SUM-163625 and edelbrock TIMING SET SBC OEM RLR CAM Edelbrock # EDL-7801
SBC TIMING POINTR 6 1/4 DAMPER SBC TIMING POINTR 6 1/4 DAMPER # SUM-163625
dutchty
uuh double post deleted
nallj92
im using the one in question, it did fit tight but i have not had any issues with it leaking at all.
